Ever heard of Vision Motorworks???
It would probably be smart to put the link in too.....
eBay Motors: 94-01 INTEGRA CAP DISTRIBUTOR EXTERNAL MSD COIL WIRES (item 260019708337 end time Aug-18-06 15:38:40 PDT)
way to go man. i see the auction has ended.
__________________________________________
www.floridasportsman.com
Originally Posted by P057
"Wow I had a hard time understanding that... but from what I gather you found an open-box item that wasn't cheaper. You bought it anyways. You then called someone a dumbass while making fun of their misfortune of losing a job as you were leaving the store?
I'm surprised you were able to get out the store with that big "SUCKER" sign affixed to your back. "
I don't know anything about that vendor.....but you are waisting your money! The best wires out there are the stock NGK wires and the stock Honda ignition is proven to well over 600whp. Not to mention I am sure if you ever went to dyno your car, you would have issues with the pickup and going through those not required ganky 9mm wires.
Thanks for the advice, I guess I won't be getting them then....but wierd thing is about a month ago when I tried to get some new stock wires they didn't fit on the distributor, its like a different plug on the end....I have an aftermarket distributor and wires so I guess their different???
What distributor do you have on there? And when you say you tried stock wires....are we talking NGK's from Honda....NGK blues?
I got a Moroso on there, was on it when I bought it. The wires that go on it have...I guess you can say has a more pointy kind of plug, and the wires I bought have a circular kind of plug at the end. I was thinking of getting an MSD distributor and the NGK blue wires....Would those go together?
