Buddy Club SPEC 4 VS. TODA SPEC B
Old Aug 5, 2006 | 08:57 AM
aznkhmerracernza's Avatar
Default Buddy Club SPEC 4 VS. TODA SPEC B
I have the options between two cams. I can get a brand new Buddy club spec 4 cams for $500 Or Some Used TODA SPEC B cams for $600. What would be a better deal and what will produce more power?
USS MAINE BLUE CREW, BANGOR WASHINGTON!!
www.myspace.com/maknpanna
Old Aug 5, 2006 | 01:17 PM
na200whp's Avatar
Powered by BOOST
what will the cams be going into? BC4's are nice if you have enough motor for them.
steve
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
Old Aug 5, 2006 | 10:52 PM
EXtreme7200's Avatar
loves beer!!!!
yea i had buddy club spec 3s in my old hatch with an ls/vtec...i absolutly loved em...go with the buddy clubs....the 4s have more lift then the bs do
Old Aug 6, 2006 | 01:09 PM
It's going into a LS/VTEC
Old Aug 6, 2006 | 01:15 PM
Cold_Beer's Avatar
Rockin' 4 more Cylinders
Depends on teh motor. And what type of compression you are tlakign here.
What are the specs on the "lsvtec" ?
RIP Robert Kolp aka 00ek 4/07
_Jake D
Old Aug 6, 2006 | 07:07 PM
I did the compression Calculator and it says 12.19 compression.
Specs are-
B18A1 Block stock 81mm bore
LS RODS with ARP ROD BOLTS
ACL RACE BEARINGS
P30 B16 Pistons
GOLDEN EAGLE LS/VTEC KIT
JDM B16A head with SKUNK2 VALVETRAIN
AEBS Intake Manifold
Type R header
Type R throttle Body
Port and Polished
3 angle valve job
BC4 or SPEC B Cams
SKUNK2 Cam Gears
AEM COLD AIR INTAKE
Walbro 255 Fuel Pump
B&M Fuel Pressure Regulator
H22 Injectors
B16 Dizzy
MSD 6AL ignition
GSR Tranny
EXEDY Stage 2 clutch
8Lbs Fidanza Flywheel
That's all I can list.
Old Aug 6, 2006 | 07:52 PM
loves beer!!!!
Specs are-
ACL RACE BEARINGS
P30 B16 Pistons
Type R header
Port and Polished
3 angle valve job
BC4 or SPEC B Cams
SKUNK2 Cam Gears
AEM COLD AIR INTAKE
H22 Injectors
B16 Dizzy
MSD 6AL ignition
GSR Tranny
with all that you will def benefit more from the bc4s trust me
Old Aug 7, 2006 | 08:42 AM
Thanks for the imput. I guess i will order the BC4's.
Old Aug 7, 2006 | 05:57 PM
T4eg's Avatar
I second that. Ive used them on plenty builds making 230-260whp all motor pump gas . Id deff go BC spec 4s all the way.
Old Aug 7, 2006 | 06:32 PM
loves beer!!!!
no prob man...just get those in there and get a good tune and lemme see them numbers....youll love it
