what size is this...?
Old Jul 24, 2006 | 08:01 AM
DA92driver's Avatar
Default what size is this...?
i need the size of the spindle nut on the integra, and will an impact gun be needed to remove it, being the lock on the nut is set? no codder pin just bent in, im sure some of you guys know what im talking about. thanks for the help.
Old Jul 24, 2006 | 08:47 AM
Cold_Beer's Avatar
Rockin' 4 more Cylinders
witch one ? there are 2 of them, either way its a 17mm or a 14mm...unless your talking about the CV nut, its a 32mm
RIP Robert Kolp aka 00ek 4/07
_Jake D
Old Jul 24, 2006 | 12:06 PM
lzylst's Avatar
sounds like the cv which is 32mm. Lots of leverage or an impact.
Old Jul 24, 2006 | 12:20 PM
SmokinS13SR20's Avatar
That ginger...
32MM + 1/2 Inch Drive + Jack Handle + Your Weight = Loose nut
Old Aug 2, 2006 | 03:44 PM
DA92driver's Avatar
cool, thanks guys
Old Aug 2, 2006 | 04:07 PM
skunk2racing97's Avatar
UF Mech/Aero Eng
dude, easiest way to do it:
get a 32 mm or 1 & 1/4, half inch drive, and like a 4 foot pipe. slip the pipe over the ratchet, and use an extraordinarily small amount of energy. torque is an amazing concept.
Old Aug 2, 2006 | 04:12 PM
Cold_Beer's Avatar
Leverage is an amazing concept.
fixed
_Jake D
Old Aug 2, 2006 | 04:32 PM
UF Mech/Aero Eng
haha thanks for the fix.
but if you want to get technical, the torque vector is defined as the moment arm crossed with the force vector. so in actuallity, torque is equal to the distance from the point of rotation mulitplied by the force. so moving the force along the lever arm away from the point of rotation increases torque, and hence, makes the bolt much easier to remove.
Old Aug 2, 2006 | 04:45 PM
Cold_Beer's Avatar
yeah but the concept is not TQ , the concept is the leverage Making the TQ
_Jake D
Old Aug 2, 2006 | 06:15 PM
UF Mech/Aero Eng
ahhh, touche sir.
and while the leverage is what makes loosening the nut easier, the base concept of torque is why it works. a force around a point of rotation is necessary before any leverage can be applied to the force.
