injector/fuel rail help
Old Jul 21, 2006 | 05:05 PM
luvsracin87's Avatar
turbo hhhmmmm?
Default injector/fuel rail help
i just bought a gsport fuel rail, and when i went to in stall it the stock injectors didnt fit like the injector isnt long enuff. so i looked at the bore in the rails where the injectors go and the gsport bores are a little bigger so do i need to just shop around for bigger injectors, or is there some kinda o-ring or bushin that goes it there??
Steve: (813) 810.4146 <~ call or text
Old Jul 21, 2006 | 05:11 PM
DOHC16CRX's Avatar
CARPET GUY
I had to take the washers/spacers off the rail that space it up and it will bolt down fine..just try that and it will work.
EATING FORDS-SHITTING CHEVY'S
MOBIL 1 LUBE
11210 Causeway Blvd. Brandon 33511
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
At the Mobil 1 Lube in brandon we service all your automotive needs.Specialize in Honda/Acura. B series swaps etc. No job to big or small.We are located right in front of Walmart. Ask for Nate.
Old Jul 21, 2006 | 05:20 PM
turbo hhhmmmm?
i wish there were some washers or spacers but there isnt
Old Jul 22, 2006 | 05:30 AM
60-1EK's Avatar
Engineer at the source
You can get larger o-rings......but why did you buy this rail again?
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Jul 22, 2006 | 05:55 AM
turbo hhhmmmm?
bigger o-rings, ill try that..............i bought the rail cuz i was planning on a turbo set up, but i thought i should upgrade my fuel and ignition systems first
Old Jul 22, 2006 | 10:12 AM
60-1EK's Avatar
Are you upgrading to braided lines on your fuel system? If not....then the stock rail will work fine. Also, the stock ignition is good to well over 500whp.
JESUS SAVES
9.69@151 Street Car
JKOBD
