? on I/M
Old Jul 17, 2006 | 06:26 PM
CivicRacingFL's Avatar
Dorado, PR
Default ? on I/M
im planning to swap my d16z6 IM for a d16y8 IM with obd2 injectors, i have a p28 chipped, can i use the obd2 injectors with my ecu
Old Jul 17, 2006 | 07:02 PM
civicSi07's Avatar
i do believe you have to use your obd1 injectors. otherwise your ecu would throw a code. a p28 is an obd1 ecu. im also guessing this honda is older than a 96, correct?
1992 Honda Civic Si: SOLD
2003 VW Gti 1.8t: SOLD
Most recent: 88' B16 Turbo CRX: Totaled
PM me if you know me!
Old Jul 18, 2006 | 02:03 AM
mtber's Avatar
92-00 civic injectors are saturated (high impedance) they do not require a resistor box
Pre 92 civics run peak & hold (low impedance) injectors & do require a resistor box.
88-91 Civic Peak and Hold 240cc
92-'95 Civic Saturated 240cc
96-'00 Civic Saturated 240cc
92-'00 Integra Saturated 240cc
90-'91 Integra Peak and Hold 240cc
92-'96 Prelude Non-VTEC Peak and Hold 240cc
92-'96 Prelude VTEC Peak and Hold 345cc
97-02 Prelude vtec Saturated 290cc
The ecu does not matter, the resistor box / injector combo does.
Another difference in injectors is the injector clips, obd0/obd1 injector clips are different then obd2 injector clips.
Old Jul 18, 2006 | 04:46 AM
Dorado, PR
mtber - so you saying i can use the obd2 injectors with the obd1 ecu i have.
Old Jul 18, 2006 | 06:42 AM
warpd's Avatar
yes they are both saturated injectors. Unless you injectors are not working properly I wouldnt reccomend it though. They both have the same flow rate (240cc) and if you want to put OBD2 injectors in your car you will have to cut and solder on the obd2 injector plugs.
(813) 523-0168 Sid
(813) 476-5383 Justin
Old Jul 18, 2006 | 09:57 AM
Dorado, PR
ty warpd
