type r pistons question
Old Jul 9, 2006 | 02:58 PM
geoff's Avatar
2fast4u
Default type r pistons question
what would type r pistons do for a gsr any hp gain would you feel a difference when driving and are type r rods a upgrade or are they pretty much the same car is a 95 gsr
Old Jan 21, 2007 | 01:12 PM
richcon's Avatar
We lol at you!
Hey man
Not too sure about the hpower gain but yes you would feel a diferance
due to higher compression , but it also depends if you are using USDM
or JDM ITR pistons USDM typeR pistons are a little higher compression than a USDM GSR so u wouldnt feel too much.
Though if you go with JDM TypeR you will be going from 10.1 too 11.1
compression = a nice little gain (:
I am about to do the sam thing in my GSR
but i am getting larger pistons
81.25 over bore 11.1 compression
but i will be doing the whole motor with cams and ect to complement
the higher compression pistons !
If you need any aftermarket parts
Let me know I own a business
CONTACT INFO:
Greg
813-641-1471
813-846-0853
Old Jan 21, 2007 | 01:20 PM
Eluzzionz's Avatar
either will yield a good difference in comp...usdm 10.83 jdm 11.36...id def go the jdm over the usdm...but id try to get the ctr pistons where ud be at 12:1...a big difference...or even p30jdm b16 11.56:1...
Old Jan 21, 2007 | 04:28 PM
T4eg's Avatar
What other mods to the motor. A stock motor wouldnt beneifit worth the $$ just to put ITR pistons in it. just my 2 cents
Old Jan 21, 2007 | 05:40 PM
skunk2racing97's Avatar
UF Mech/Aero Eng
you will get a gain, but like T4eg said, by itself it wont be huge.
a set of ITR/CTR/skunk2 cams and an ECU chip would bring some pretty solid gains out, without too much money.
g/l
Old Jan 21, 2007 | 06:08 PM
JDMBlackGSR's Avatar
Gators Bitches!
yea, i got some decent gains with my type r pistons and skunk2 cams. The compression raise wont do to much alone....like everyone else has said
2003 Accord EX-L V6
Interior
'07 Shift Lever♦Diode Dynamics Stage 1 LED's
Exterior
HFP Front & Rear Lip♦Limo Tint♦LED Smoke Tails♦Yellow Fogs♦8000k Low Beam HIDs♦LED Reverse Bulbs♦Gunmetal Stock 7 Spokes
Suspension
Rear Lower Tie-Bar♦Front Strut Bar♦TL-S Rear Sway Bar♦MOOG Rear Endlinks♦HFP Suspension♦Ingalls Camber Kit
Engine/Performance
Nokya Battery Tie Down♦Spoon Radiator/Oil Cap♦Skunk2 Clutch Cover♦Stainless Brake Lines♦TL Engine Cover♦RV6 J-Pipe & Test Pipe♦Short Ram Intake
Old Jan 21, 2007 | 06:13 PM
KJ's Avatar
KJ
bored at work
Stay away from ctr's. USDM b16a pistons are a good upgrade and usually work out to about 11.5:1 which is perfect for a street 93 octane motor. The CTR's due to their difference in comp height (wrist pin to crown) have a higher compression ratio than most of the available calculators say. With a gsr head you will end up alot closer to 12.5:1.
Old Jan 21, 2007 | 07:38 PM
99B16Si's Avatar
bringing one back from the dead huh?
Old Jan 21, 2007 | 07:43 PM
UF Mech/Aero Eng
hahahhhaa
shit.
Old Jan 21, 2007 | 07:58 PM
Eluzzionz's Avatar
thx kj for correcting me...i def used a comp calculator ..thinkin 12:1 would be the highest i would go on pump gas...goodlooking out...
