turbo oiler line for a crx?????
im having problems with my crx the turbo oiler line keeps tuching the exhaust pipe and keeps leaking i tryed holding it back but it keeps blowing oil all over and im stumped........ so i came here help a brotha out.......................
1993 hatch-Building
1998 Z71
2004 GSX-R 1000
1993 hatch-Building
1998 Z71
2004 GSX-R 1000
Feed or Return ?
I'm assuming the return here . You need tog et the straighest route back to the oil pan you can without Kinks . Use Braided A/N and put a protective heat wrap around it or something . I have a regular braided A/N line and it doesnt touch the DP at all ..
Hondata saves lives
Hondata saves lives
cool bro thanx ya i was going to do that today but a&e was closed ... but the kid that had it put the return line about 1 inch to the driver side and it screwed eveything up....but i will try that
1993 hatch-Building
1998 Z71
2004 GSX-R 1000
1993 hatch-Building
1998 Z71
2004 GSX-R 1000
Can you insert an adapter on one end or the other of the line and push it slightly away from the exhaust in that manner?-Bob
um i was going to put a fitting on there but it's like 1 inch from being stright with the turbo but i think i can put a steel braded line on there with the fitting's.......we'll see thanks bob
1993 hatch-Building
1998 Z71
2004 GSX-R 1000
1993 hatch-Building
1998 Z71
2004 GSX-R 1000
duct tape and zip ties...
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
