y8 cam in z6?
i found a crower stage 2 cam for a y8 head. can i use this in the z6 im putting on my d15b8. i have a d16a6 intake and dizzy. i dont know if it matters but the cap and coil are externals and aftermarket. im running a pm6 head. will there be any other problems and which springs and valves and retainers should i go with
Intake manifold, dizzy, cap, and coil make no difference.
There is no reason to state that you are running a PM6 head if you say you are using a Z6 head.
I can't tell you if a Y8 cam will work, however.
