compression test numbers on stock gsr?
Old Jun 8, 2006 | 02:51 PM
TIM TIM TIM's Avatar
could be worse
Default compression test numbers on stock gsr?
well my motor is supposed to be built, but i did a compression test and i got 210,200,200,220.... those seem kinda stock.... am i wrong?
aim:because tim said
Old Jun 8, 2006 | 02:58 PM
aj187's Avatar
FORE:exalt
Standard stock compression on a gsr is 270.
Old Jun 8, 2006 | 03:53 PM
SmokinS13SR20's Avatar
That ginger...
mm BOOSTAGE!!
Old Jun 8, 2006 | 05:14 PM
could be worse
so 200 would be pretty damn low then?
Old Jun 8, 2006 | 06:27 PM
mtber's Avatar
Yes that would be low.
Did you do the compression test with the motor warm at wide open throttle ?
Did you disable the fuel pump (pull the ecu fuse) ?
Old Jun 9, 2006 | 02:37 AM
could be worse
warmed up and pulled ecu fuse.. i didnt do WOT though, will that make the differance?
Old Jun 9, 2006 | 02:38 AM
could be worse
i can tell its running rich as hell, after i drive a while its a pain to get started, and the plugs are all black lol
Old Jun 9, 2006 | 03:58 AM
KJ's Avatar
KJ
bored at work
200 is normal for a stock gsr.
Old Jun 9, 2006 | 04:30 AM
Jaso0on's Avatar
Is now ballin!
Is this the car thats suppose to be sleeved, 12.5:1 c/r, etc. etc.?
RIP Kevin (Slo_Si) Gonzalez - 09/13/2006
Old Jun 9, 2006 | 01:10 PM
Sabotage's Avatar
slash
i got 214-214-214-214 on my stock gsr ...i dont feel like looking for the #s, but i know when i did it and was looking at the book and it looked good. yours do seem low though.
meows meows
TRick Squad Member #3
VicPrez of IttyBittyTittyCommittee
