wiring on A/F ratio gauges
Old Jun 6, 2006 | 06:33 PM
jst4shw's Avatar
Default wiring on A/F ratio gauges
i got a 2000 civic si and i installed my A/F gauge and its not working right,. i connected it to the white wire on the o2 sensor, can someone help me out
Old Jun 6, 2006 | 06:38 PM
Gixxer's Avatar
Hide your daughters
Is it a narrowband guess-o-meter or wideband?
Try hooking it up directly to the O2 sensor (white wire).
Old Jun 7, 2006 | 01:15 PM
integrex's Avatar
whats it doing?....more info please
Old Jun 7, 2006 | 02:46 PM
jst4shw's Avatar
i`m not sure, but i think its a wide band, , tis a autometer sport-comp
Old Jun 7, 2006 | 02:50 PM
jst4shw's Avatar
when i start the car ,it`ll be on green then when the car warming up, start to go down al the way to red
Old Jun 7, 2006 | 04:57 PM
60-1EK's Avatar
Engineer at the source
Is is a guess-o-narobando meter. Very accurate in between 14.1 and 15.5:1 AF. Outside of that, I guess your ride is about to BLOW!!!!
eh...I guess I will answer your question....nothing is wrong with your gauge except that is doesn't work very well and is more for a cool flashy display. If you did say get the PLX M250, you could use the auto meter gauge and wire it to it and the gauge would read accurately.
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Jun 7, 2006 | 05:12 PM
Blown99civicSi's Avatar
EFI Tech/Tuner
^^^ This is what I run on my setup, the converter cost like $30, the PLX is a bit more but worth every penny, if you like to know if your motor is on the edge of blowing up from running to lean or you are washing your cylinder walls clear of oil from running to rich.. your choice
Modified Racing
Street Tuning & Dyno Tuning the greater east coast area for over 10 years and running!
AEM/HONDATA/MOTEC/FAST/DEFI & More
EFI-101 Certified
(941)628-4988
