Car not starting
Old Jun 4, 2006 | 05:47 PM
Hater's Avatar
Free base cocaine
Default Car not starting
Ive been having some trouble latly getting my 94 civic with a d15, to start car has 70xxx miles on it and i turn the key and i hear the starter turning, then the battire light flashes and thats it. I can get it to push start and then it turns on after that. but ive had it happen twice.
Old Jun 4, 2006 | 06:07 PM
Gixxer's Avatar
Hide your daughters
Check plugs to see if you're getting spark.
Fuel pump priming?
Old Jun 5, 2006 | 02:05 PM
DemonCivic's Avatar
it pop starts easily? is the starter engaging the flywheel and rotating the motor? does the starter release before it starts? more info please
Old Jun 5, 2006 | 02:28 PM
Hater's Avatar
Free base cocaine
the started isnt engaging the fly wheel i think, it happend again today, and i pumped the clutch like three times and it started up. i checked the plugs and everything looks good.
Old Jun 5, 2006 | 04:57 PM
DemonCivic's Avatar
if the starter is not engaging the flywheel, the starter solenoid is going bad. either replace the entire starter or remove and replace the solenoid.
Old Jun 5, 2006 | 05:20 PM
Derka's Avatar
TR Balla Donor Supreme
If the soleniod was bad the starter wouldnt engage at all, it would probly just click. It sounds like the bendix in the starter isnt engaging. Time to replace the stater
1998 crv daily beater
Old Jun 5, 2006 | 06:09 PM
DemonCivic's Avatar
the bendix is what makes the starter spin, yes the solenoid supplies power, but it also injects the shaft to engage the flywheel. his complaint was that the starter spins but doesnt engage. if it spins the bendix is doing its job.
Old Jun 6, 2006 | 10:49 PM
Sounds like a starter problem more than an engine problem.
What part of the starter? ..... depends on whether the starter is engaging,
but not spinning the flywheel. Or not engaging at all.
Also check the battery connections. Super clean/grease the terminals
on both cables and also on the battery itself. Crud can affect
the starter not having enough electricity to crank the engine.-Bob
Old Jun 7, 2006 | 12:47 PM
Hater's Avatar
Free base cocaine
this sounds kinda pluasable because im not to sure the starter should be going bad, how long do starters usaly last for?
Old Jun 7, 2006 | 01:16 PM
DemonCivic's Avatar
sounds familiar
