d16y8 in eg O2 sensor PROBLEMS!! HELP
I am close to driving my civic into a river...It's a 95 dx civic w/d16y8 swap. My O2 SENSOR LIGHT...CEL#1...came on so I put in a new $90 sensor. Surprise, light is still on after disconnecting the battery after driving it for quite a while. And if that's not enough, my VTEC is intermitent and the CEL #22 goes on for "VTEC oil pressure swicth". If anyone has a real live-feed scanner that can tell me what my sensor say real-time, I'd appreciate it along with any advice. Thanks.
Also I have a d15 out of my 95 dx civic w/auto tranny 4 $100...merry friggin Christmas.
I left out some details...I have a p28 ecu and used the original obd1 harness off the dx and added the vtec wire and oil pressure wire to the ecu. It has to be pinned correct because the vtec briefly worked then stopped. If I could hook it up to a scanner while it runs I could see what the o2 sensor is doing along with the vtec pressure signal....keep the tips coming, we can make this poor sohc run right again, but only with some help...
are you useing a 4 wire o2 sensor? also alot of hondas dont take to well to non oem o2 sensors. also check your oil level for the vtec problem since the y8 is notrious for oil consumption, which leads to a blown motor.
screwed by wb_map3
https://www.tamparacing.com/forums/b...pinions-9.html
1995 Turbo Ex Coupe
14.2 @99 8psi, street tire full interior with lots of crap in the car. SOLD
03 GSXR 600 Toy SOLD
1994 Acura Integra Sedan Daily SOLD
1993 Honda Civic Si PArted and Sold
07 GSXR 600
c280 Daily
screwed by wb_map3
1995 Turbo Ex Coupe
07 GSXR 600
c280 Daily
