will it work?
will it work?
i have a mini-me turbo. i kno the Ls pistons are a lot thicker than the stock d16 ones. if i put some SRP pistons on the Ls rods, would it fit into my d16 block?
any modifications or plop in?
or flat out doesnt work?
engine building &best
on
well only a couple things wrong here..
1.ls piston with not fit d series rods do to the different size pins that hold them in
2.ls pistons with not fit into d16 block do to ls are 81mm bore and d16 are 75mm
3.if your going to order srp pistons JUST ORDER them for a d16 you can use them on your d16 rods
i love AUTOZONE
i love AUTOZONE
yep, you can use the LS rods in your D16a6 motor. you will need some mods though!
1st the wrist pin bushings have to be changed to fit the smaller D series wrist pins, and you also have to clearence the block because the bigger rods wont turn all the way around without hitting!
NO EXCUSES for my lil FWD! Cmon RWD's n AWD's, lets DIG!
STEISS RACING all the way
HONDA ENGINES from oem to EXTREEM
www.myspace.com/streetracin_cwby
http://www.facebook.com/#!/profile.php?id=1433200141
i did order them fora D series.. jus say'n, i can get Ls rods for free and i kno they're bigger than the D series stock rods. i heard bout it being done but i was jus checkin to see what needed to be done. i knew about the wrist pin part.. so basically jus notch the bottom of the block n ill be strait?
you got it mang!
can ya get any more for free cause i need a set too! lol
on
it takes alot to get the ls rods to work.you need a very good shop to matchfit wrist bushing for you and have them pined in right..trust me i have tryed it couple of times with sad results...good luck its alot easier to spend the money on hbeam rods im sorry to say
i love AUTOZONE
i love AUTOZONE
