intake manifold help.
Old May 30, 2006 | 04:01 PM
magic carpet's Avatar
Default intake manifold help.
i have the dual point fuel injection on a 91 d15b2. a few questions.
edit: i am doing a mpfi swap, thats y im asking.
does anyone have an old crx si intake manifold i can buy?
will a y7 intake manifold work?
and does obd matter?(like if i get the y7 intake will i need to convert more stuff??)
Old May 30, 2006 | 04:21 PM
mtber's Avatar
I do not recommend the y7 intake manifold. It is a horrible design & has a 3 wire idle air control valve.
Old May 30, 2006 | 04:33 PM
integrex's Avatar
+1
its allways easier to use an si one but if all else fails use a d16z6 (rather easy) or the d16y8 (a lil harder)
and dont forget to get a resistor box, ecu, distributor, harness....
either way good luck on your swap
Old May 30, 2006 | 04:36 PM
freakasis's Avatar
how much power to you get from this swap? and do you get any more mpg's?
Old May 30, 2006 | 04:39 PM
integrex's Avatar
eh....depends on your driving...but it opens you up to the performance world as in anything thats worth buying performs better and/or only works with multi point
i drove to orlando stayed for two days drove back and still had a quarter tank of gas with just a multi point swap.....(if that helps)
Old May 30, 2006 | 04:45 PM
thanks for the help!!
