rear disk conversion
Old May 29, 2006 | 09:00 AM
importedperformance's Avatar
Default rear disk conversion
will a 91 crx si disk conversion fit on an 88 crx dx, because i just pulled the suspension out and would like to know.
Old May 29, 2006 | 11:25 AM
integrex's Avatar
yes but you have to take it all (as in everything thats bolted to the frame)
just did the same thing on a friends car
Old May 29, 2006 | 08:23 PM
effDOHC's Avatar
About That...
i did the same but i used 93 del sol brakes and put it on a 90 crx went pretty smooth...
Old May 31, 2006 | 04:37 AM
DOHC16CRX's Avatar
CARPET GUY
make sure you only use the trailing arm only for the disk set up..You must use the crx camber bars and lower control arms as well as the caster arms.
EATING FORDS-SHITTING CHEVY'S
MOBIL 1 LUBE
11210 Causeway Blvd. Brandon 33511
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
At the Mobil 1 Lube in brandon we service all your automotive needs.Specialize in Honda/Acura. B series swaps etc. No job to big or small.We are located right in front of Walmart. Ask for Nate.
Old Jun 4, 2006 | 09:23 AM
yeah i pulled everything off, but im waiting to rebuild the bearings before i throw it on
