integra jus turned off
Old May 29, 2006 | 01:55 PM
  #21 (permalink)
Cold_Beer's Avatar
Rockin' 4 more Cylinders
is it getting fuel???????? check all your fueses also.
RIP Robert Kolp aka 00ek 4/07
_Jake D
Old May 29, 2006 | 02:37 PM
  #22 (permalink)
Josh.'s Avatar
The Integra Guru!
fuses. in the Engine compartment.
04' Crystal White Lexus IS300
04' Premium White Pearl RSX-S
Originally Posted by 94lsteg
Old May 29, 2006 | 06:05 PM
  #23 (permalink)
useurtoolswisely's Avatar
fuses all good changed the fuel pump dizzy ecu... and still wont turn on....
Old May 29, 2006 | 06:11 PM
  #24 (permalink)
rangcrx's Avatar
engine building &best
you sure one of the ecu plugs did not come out,
i love AUTOZONE
Old May 29, 2006 | 07:19 PM
  #25 (permalink)
yup took it out 3 times and put in 2 diff ones.....
Old May 29, 2006 | 08:05 PM
  #26 (permalink)
Cold_Beer's Avatar
main RELAY DEFINATELY.
Driver side, under the dash right near the fuse box....it has a 10mm bolt holding it onto the side....has liek 14 wires ran to it.
_Jake D
Old May 29, 2006 | 08:35 PM
  #27 (permalink)
truu ill change it in the morning and c if that helps....
Old May 30, 2006 | 09:58 AM
  #28 (permalink)
Jay's Avatar
Jay
Janky
dizzy or main relay is where i would start. see what your not getting first fuel or spark or both.
Aim: o JankyJ o
http://jankycrew.com
Old May 30, 2006 | 10:40 AM
  #29 (permalink)
Mujaki's Avatar
Agreed. Try to resolder the connections in the unit before you go and buy a new one. They tend to wear out with age and heat.
Old Jun 3, 2006 | 10:35 AM
  #30 (permalink)
replaced dizzy, main relay, wire harness, fuel pump. and it also keeps poping the ecu fuse under the hood......
