Going from ls to ls/vtec
Old May 21, 2006 | 07:15 PM
bagged94civic's Avatar
Default Going from ls to ls/vtec
Ive been searching for awhile and i finally wanna go ls/vtec.
I was wondering if i get a complete gsr head and a golden eagle ls vtec kit, will that be all I need.
has 8:5 compression and kms blockgaurd and eagle rods. full turbo kit
Also how much money is this gonna cost to install. Where would be a good place or person to get to do the ls vtec conversion
please leave me some feedback
thanks alot
[FONT=System]
Ls turbo teg
Old May 21, 2006 | 09:54 PM
DemonCivic's Avatar
also install ITR Oil Pump and ITR Water Pump
Old May 22, 2006 | 03:27 AM
EXtreme7200's Avatar
loves beer!!!!
i would also go with the b16 or gsr transmission...shorter gears
Old May 22, 2006 | 03:47 AM
Old Renegade's Avatar
Cool Runnings
to do it right is going to cost some change like higher compression pistons with rings, gaskets, seals, bearings all misc. stuff. i say this if you not going to half ass stuff and do it right the first time. totally re-doing the block an parts "do not mean sleeving" and totally upgrading the head. cams valves valve spring retainers and all that good stuff.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old May 22, 2006 | 07:40 AM
99B16Si's Avatar
a lot can be had without swapping the pistons. 10:1 compression is easily obtained by just shaving the head or using a thinner headgasket....dont forget the ECU also
Old May 22, 2006 | 02:01 PM
i dont want high compression im runniing 18 pounds of boost
[FONT=System]
Ls turbo teg
Old May 22, 2006 | 03:05 PM
Cool Runnings
well you never said that you were boosted and most people hear ls\v-tec and think all motor.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
Old May 23, 2006 | 03:51 AM
loves beer!!!!
yea most pple think that boosting an ls/vtec is just gunna blow it up...which is very tru because the ones with the b16 heads are known to have some pretty high compression...but boosted ls/vtecs if you do them right are just sick
Old May 23, 2006 | 05:14 AM
99B16Si's Avatar
stock ls bottom end with b16a head = 9.5:1
stock ls bottom end with gsr head = 9.7:1
compression ratios are barable for boost
Old May 23, 2006 | 06:30 AM
did i mention i have srp 8:5 compression pistons in my ls right now?
[FONT=System]
Ls turbo teg
