GSR valve train in b16a1????
Old May 21, 2006 | 04:43 PM
TurboJdmEk's Avatar
is on blocks...
Default GSR valve train in b16a1????
i have a b16a1 head and i got an awesome deal for a pair of gsr cams, springs and valves, all with only like 30k on them, now i want to drop this in my head and if i did what type of hp gains should i look for and will it increase my acceleration or top speed i know the b16 is a high revving head but is this setup going to do good in my car the head is on a 97 stock gsr block and i am going turbo if that makes a difference maybe it raises compression ratio?? i dunno just lmk what i should look for is it worth swapping those out?? lmk asap guys really need some help and if no one tells me its the wrong thing to do because if no one lets me know by tomoro theyre going into the head lol
its coming...
Old May 21, 2006 | 04:51 PM
integraman89's Avatar
lost u already???
the only thing i can see being a problem is the difference in lobe sizes...valve clearence... i dont know if by putting in those cams that they can cause danger... but i hear the gsr cams, valves and springs are better than the b16.
if you got a good deal on those parts, take it... then if those parts dont work out, sell them.
Old May 21, 2006 | 05:17 PM
Jap's Avatar
Jap
VTEC Out
Cams yes no need for the other stuff ..
Unless they are aftermarket , then ok yes .
For boost GSR > B16 Cams
Hondata saves lives
Old May 21, 2006 | 05:28 PM
TurboJdmEk's Avatar
is on blocks...
ok thanks the cams will be going in tomoro and i will sell the valves retainers and springs how much should i look to get for them??
its coming...
Old May 21, 2006 | 07:45 PM
civicized's Avatar
There are no valve clearance issues but this generally is not a worthwhile upgrade. You will not see any difference in performance.
Old May 22, 2006 | 07:51 AM
InsaneCivicCoupe's Avatar
Retired Ricer...
I think you forgot to put the " " after that.. You were joking, right???
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old May 22, 2006 | 09:07 AM
lost u already???
haha.... so it does make a difference in hp?
Old May 22, 2006 | 09:48 AM
Retired Ricer...
yes, a larger cam is always going to make more hp... You may not gain 973.6whp just by switching from b16 cams to gsr cams, but you will gain some... The biggest gain will come in the tuning.. Once you smooth the vtec crossover and tune the map to match those cams, you will see the benefit... this is true for FI as well as all motor... Cams make a difference if tuned... You cant just throw em in there and expect to feel a difference...
Old May 22, 2006 | 11:36 AM
TurboJdmEk's Avatar
is on blocks...
thanks alot guys and some info on tuning would help also i heard phearable.net was really good and i was thinking about going with them how much do they charge to tune my car?? is it like an hourly thing or do i just buy one of his chipped ecu off the site lmk what i shoulddo thanks alot guys, john
its coming...
Old May 22, 2006 | 02:05 PM
Retired Ricer...
go to www.phearable.net to view his rates and services
