Drive shaft Axles Remove
Old May 21, 2006 | 09:55 AM
Tightcivicexboii's Avatar
Honda Gear Head
Default Drive shaft Axles Remove
My friend and i was removing my shortblock so that i can sell the long block to someone and i didn't have a good enough wrench to take off the ones below and i wanted to know to be able to take the tranny and block and axles out together can i remove the hub bearing and loosen the axles to pull the whole thing?.. Thanks all.
No project currently. Getting my ASE Certifications Completed.
Old May 21, 2006 | 10:50 AM
vonrobins's Avatar
love hondas ftw
The Way I Usually Do It Is Take Out The Axles First Then Mounts And Drop It Out Theres No Need To Drop The Whole Arm Really Unless You Just Want To Or You Cant Get Ur Axle Nuts Off Lol
._________________________
Old May 21, 2006 | 10:57 AM
Cold_Beer's Avatar
Rockin' 4 more Cylinders
Loosen the big axle nut first then Pop the bottom ball joint ( 1 bolt) and take out the bottom strut bolt, axle comes out. then the linkage , then drop the car all the way ont eh ground....pull the mounts...jack the car back up... Done.
RIP Robert Kolp aka 00ek 4/07
_Jake D
Old May 22, 2006 | 10:17 AM
Honda Gear Head
Thanks ya'll
