H22 into Ef9??? Can it be done????
Old May 18, 2006 | 03:26 PM
TurboJdmEk's Avatar
is on blocks...
how much would it cost to have someone make them?? ball park??
its coming...
Old May 18, 2006 | 07:37 PM
vonrobins's Avatar
love hondas ftw
do a search for coleon on tr user about a year ago he had a h22 in his crx and eg hatch
._________________________
Old May 18, 2006 | 07:38 PM
Cold_Beer's Avatar
Rockin' 4 more Cylinders
it's jsut as easy as a B series......hasport has everything you need...even a write up.
RIP Robert Kolp aka 00ek 4/07
_Jake D
Old May 18, 2006 | 07:42 PM
Cold_Beer's Avatar
Originally Posted by SmokinS13SR20
Most likely will need the custom shiftlinkage, not sure one might fit. You would use the H22 ecu.
Headers should be fine, and the wiring harness will have to fit into the ecu. If the wiring harness has to be modded, it will be a simple matter. Should have some writeups online check around on www.honda-tech.com
H22's use the same plugs as a b series.....all that needs to be done is converted to obd1 and lengthing of a couple wires.
I recommend when swapping a H22.....
1.Converting from a Hydro timing tensioner to a Manual H23 tension (waay easier to work with )
2. Doing away with the EGR ( Ie. use a block off plate )
3. Run a chipped ECM with the porper base map and w/ no knock, speed govenor or EGR chipped out.
4. Do not run the car hella low as it will put the axles in a bind and snap them.
5. Search search search...the only way to learn is to do it yourself.
6. Also i recommend running a internal coil dizzy as they are easier to work with and also run a dizzy w/ a internal crank sensor ( obd2's have them at the crank pulley)
Note: You cannot chip a p13 or p14 ecu's cannot be chipped and used w/ crome, uberdata etc...,. i personally recommend a chipped www.phearable.net ecm and john will set you up with the propper base map.
Also when converting to obd1 i recommend only Rywire/jkobd harness as i have never had a problem with them and they work flawlessly.
~Jake
_Jake D
Old May 19, 2006 | 03:49 AM
Old Renegade's Avatar
Cool Runnings
+1
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old May 19, 2006 | 06:43 AM
  #17 (permalink)
TurboJdmEk's Avatar
is on blocks...
^ tru thanks alot guys for all the help
its coming...
Old May 20, 2006 | 11:28 PM
  #18 (permalink)
Walter's Avatar
Im as loyal as my options
http://www.explicitspeedperformance....H22AHowTo.html
blah blah blah
Old May 21, 2006 | 05:07 PM
  #19 (permalink)
hondahunter's Avatar
pass the dutch
h-series is gay
shared_pm me for great prices on hydro and organic garden setups aswell as all the goods you need to grow cheaper than the big guys. built for youre needs. save money on fruits and vegetables. i dont sell any illegal products goods or services just fully ready to grow closets and rooms.
Old May 21, 2006 | 05:19 PM
  #20 (permalink)
Walter's Avatar
Originally Posted by hondahunter
h-series is gay
so are ludes
blah blah blah
