A/C & idle question
A/C & idle question
this is on a 94 civic ex.
I had the car A/C charged today, and the below problem just started after that, i did not have the problem before today.
when i run my A/C the idle seems to feel like it has a big lobe to it when stopped, or an eradic idle. when i turn the A/C off, it does not do it.
also, when i drive with the A/C on, it feels like someone keeps pulling on the ebrake, and kind of hesitant, but when i turn it off, the problem goes away, or you cant feel it anymore.
anyone have any suggestions?
Originally Posted by DemonCivic
who charged the a/c? sounds like they overcharged it and the system is unable to flow properly.
+1 Demon civic. -Bob
put a set of gauges on the a/c system and see what the pressure is.
check the pressure with the car running and the a/c on
low side should be between 50-60
high should be around 250
