ls/vtec or b16a2
Befürchten Sie Meinen Zor
on
ls/vtec or b16a2
which would be better to get for turbo and just a simple set up...nothing fancy....just something decent...thanks
Vincent Mancini : Don Lucchesi, you are a man of finance and politics. These things I don't understand.
Don Lucchesi : You understand guns?
Vincent Mancini: Yes.
Don Lucchesi: Finance is a gun. Politics is knowing when to pull the trigger.
LS/Vtec is more costly to do right, but results in more power over the B16a but the B16a is cheaper and can be bought together and then turbo added where you would have to get a Ls then drop either a b16a head or GSR head on it to have your Ls/vtec and then add the turbo. If your gonna get turbo you minus well get the LS/Vtec to feel good about the power and look at the empty account later.
No project currently. Getting my ASE Certifications Completed.
b16 will be easyer and more cost efective i beleive the ls/vtec would make more power.
I don't have a LS long block. I know it should be more diffcult and not just head swapping, but i wanted to choose the LS/VTec turbo because i seen it move and was amazed with it. I am as we speak swapping and gonna be driving on a mini-me swap for now and was gonna get LS and swap out my mini-me, try and sell it for a decent price since it's fairly built. Then get the necessary parts for my LS/VTec swap during the year and by like may of 07 i will be graduating and my graduation present will be turbo so i wanted to just drop the turbo on that, basically. But hey, i never seen it run against a B16 turbo and i know about the short rod to stroke ratio, but that can be altered if wanted. I'm not gonna be running all the time i might just go all motor N/A and just build without boost or spray.
