Help! Drystarts!
I've finally got my motor I've been building for about forever started up. The motor has killer drystarts, everything in it is brand new. I don't know whats causing this or what I can do to prevent it. heres the breakdown:
B18A1 Stock crank
ACL race series bearings (mains and rods)
Eagle Rods
Srp Pistons
Jdm B16 head
Gsr oil pump
motor is still in break in process... running standard oil 10w-40
Thanks -Ben
B18A1 Stock crank
Eagle Rods
Srp Pistons
Jdm B16 head
Gsr oil pump
Thanks -Ben
fucking midget's inside with a hammer is what it sounds like.
RIP Robert Kolp aka 00ek 4/07
_Jake D
_Jake D
Race series bearings usually give too much clearance. Did you check the clearances. My guess is that they are too loose. Also what was your piston to wall set at.
Gracie Barra Clearwater
it starts right up. As of now stock injectors.....it's just N/A at the moment....
Kevin, he used under sized bearings from acl. Didn't Guage the crank or anything, just ordered a set of undersized ones.
_Jake D
_Jake D
Originally Posted by lzylst
was the blocked bored?
Piston to wall slap????????
it's not piston slap.
_Jake D
_Jake D
