H22 Question
Old May 5, 2006 | 12:42 PM
pimpingreen13's Avatar
Default H22 Question
Im in the process of building a H22 and IM running Type S pistons but want to run the compression a bit higher. The question pretty much is should i shave the head or get a thinner head gasket? Or should i do both? Does anybody know where i could get a thinner head gasket online? If i shave the head how far can i go? Any help would be appreciated. thanks
Old May 5, 2006 | 06:52 PM
integraman89's Avatar
lost u already???
you dont wanna go too thin, cuz then you will have less valve clearence, i would personally just go with the thin head gasket.
Old May 5, 2006 | 06:56 PM
freakasis's Avatar
Originally Posted by integraman89
you dont wanna go to thin....i would personally just go with the thin head gasket.
dont got thin...go thin...what are you tryin to say?
Old May 6, 2006 | 05:23 PM
anybody know how much you can shave off safely with a 1 layer headgasket?
Old May 7, 2006 | 08:53 PM
lost u already???
what i mean is if you machine your head and go with a thin gasket you will have alot less valve clearence (too thin) meaning the less your valves can open the less intake and exhaust can pass through.
Old May 7, 2006 | 09:07 PM
Got_my_air_on's Avatar
Don't worry, its stock.
I would shave the head, I did that in my civic and it worked pretty good, you just cany run nitrous, or so i hear.
Old Skool
Old May 12, 2006 | 01:59 PM
how much did you shave it?
Old May 14, 2006 | 05:23 AM
BudDyLeE's Avatar
My car cought on Fire!
If you put in Type S pistons, you dont wanna go thin. just go normal... we put clay on the piston and turned the cam's to see how much clearance it had on the H22, and it was good enough.. Any Closer you the Valves would've touched the piston's.. Any good Headgaskets will work for you... .. To be on the safe side(put 4 tiny pieces of clay on one piston*make sure you put one in the middle of the piston,*highest point*<<TypeS's are pretty tall>>)..
once you got the (OLD)HeadGaskets in, put on the head/tensioner/belt, spin the the cam manually, and MAKE SURE you lock the Vtec on that certain piston when your spinnin it as well, that way you not only check on regular driving, but with VTEC as well.. after just take it all apart again and see how much clearance you have... If its done right, the (tiny pieces of clay, should have hardly or no squoosh from the valves..
All this could be done easily if you have an engine stand and space and garage.
<<<<(Reps anyone)
