For all you aftermarket piston N/A guys....
11:1 total compression. Would you run an aftermarket headgasket or use an OEM gasket? I'd think OEM would be better since the comp ratio isn't gonna be TOO high. I won't be using Nitrous either.
-Joe
-Joe
thats not nearly high enough to not use an OEM headgasket.
you will be fine, and OEM is the highest quality availible
Alright, thanks man.
Do you have any suggestions on Pistons and/or Rings?
I plan on having 11:1 compression as stated above, Stage 2 cam, Skunk2 Intake Manifold, and Skunk2 valvetrain.
damn im going to be 13-1 and im going to run OEM hell the whole motor is going to be oem - rod bolts.
RIP Robert Kolp aka 00ek 4/07
_Jake D
_Jake D
Originally Posted by SmokinS13SR20
Ok, Jake what pistons are you running?
OEM p30's
_Jake D
_Jake D
GSR cams are the best econmical cam option for a turbo app. ITR/JDM ITR would be better but require more tunning and cam gears ...
Hondata saves lives
Hondata saves lives
