change rod bearings without removing head?
on
i got a y8 and i was wondering of it is possible to change the rod bearings from the oil pan?....my rings and everything are goood but i dont wanna chance spinning a bearing since it has like 200k on it. iv done it on other engines before just never on a honda. dont know if you fit your hand around the crank to put the top pieces in.
thanx
thanx
engine building &best
on
/\ like said its very very easy i have done it alot,not really a tight fit cause on the sohc you have to remove the whole suppert maincaps..so there is alot of room you dont have to fit you hand around you just lil time to romovet he bottom half the push piston up and turn the crank to mid then pull the whole thing down,makes it easy
i love AUTOZONE
i love AUTOZONE
on
oh AND please buy latex dont change them with dirty ass hands change the gloves for every rod
i love AUTOZONE
i love AUTOZONE
on
thanx....
by the way since i have to remove the main caps anyway, can i change the main bearings too? i know you cant pull the crank down but maybe i can turn the bearings in or somthing? or should i just not worry about em?
no you don't have to remove the main caps for change the rods bearings and no you can't change the main bearings with out removed the motor cause the flywheel and cluth. hope it helps
on
i love AUTOZONE
i love AUTOZONE
R.I.P. Kevin Gonzales Aka Slo_Si
You will be missed by many.
R.I.P. Robert Kolp Aka 00ek
You will be missed brother
R.I.P Jake D Aka Cold_Beer
you will be missed brother
