more and more headaches
Originally Posted by EludeR
I would say so, it's definetely fuel related. I would have another tuner look it over imho. if your AFR isn't rich (at any point in given time), then you wouldn't have all this carbon buildup on your plugs.
-Pete
Originally Posted by juiced2ndgenteg
This is VERY true. I know I'm far from you but, if you want, come take the trip I'll put my wideband in and check your A/F ratio's out for free.
-Pete
-Pete
does crome use adaptive strategy? if not the injectors would be at a preset pulse width no matter what right? if this is the case if i had say an abnormal build up in fuel pressure in the rail, the injectors would still pulse the same thus flooding me out.
and i am programed for no o2. still have stock map as well, not sure if its even utilized though.
If that was the case your plugs wouldn't be black. they would be a paper bag brown. If your plugs are black your running tooo rich. as in the 11's and 10's a/f. This is why I think you have a harness or sensor plroblem. It is a intermittent problem.
