Breaking in a new engine questions
Old Apr 25, 2006 | 08:48 AM
uyht's Avatar
Default Breaking in a new engine questions
Is there a generally acceptable way to break in a new never been run engine?
I found this http://www.mototuneusa.com/break_in_secrets.htm online but would like opinions. Of course I will talk to my builder/installer/tuner as well but would like to be as informed as possible. The one thing everything I read seems to say is, change your oil and check your oil filter after 20 miles, and keep doing so until the filter is clean. Also it says to not use synthetic inially, until you have about 1500 miles on it. Is this correct or is all opinion?
--Its all good--
Old Apr 25, 2006 | 09:17 AM
The Spectacle's Avatar
Spent more money than you
It will run as hard as you break it in!
Racing Integration
LHT Performance
My tuner is named Alpha
Old Apr 25, 2006 | 10:38 AM
lzylst's Avatar
definately DO NOT use synthetic during break in.
Everyone has their own opinion so get ready for it.
Old Apr 25, 2006 | 10:41 AM
uyht's Avatar
vance is the man. Yea there are a lot of articles on it. I think i am just gonna take it to AntiVenom and dyno it after i run it for a few.
--Its all good--
Old Apr 25, 2006 | 12:14 PM
DD.'s Avatar
DD.
Administrator
Dont listen to spectacle j/k
...I dont think you should really get into it untill AFTER 1,000 miles
Old Apr 25, 2006 | 12:22 PM
shimano's Avatar
from what ive read tuning is very important at startup
99 Civic Hatch - Turbo - Tuned By Phearable.net
92 Civic Hatch - NA - Tuned By Phearable.net
Old Apr 25, 2006 | 12:42 PM
Alpha's Avatar
The first twenty five minutes of starting a motor are the most critical IMO. Start it up. Get a steady idle with an ideal A/F. Check for leaks and let it get up to operating temperature once. Change the oil and change the oil filter. I recommend Supertech oil and filter for startups. Start it again. Hold it at 1,500RPM - 2,000RPM for fifteen minutes. Change the oil and change the oil filter. Use whatever oil and filter your going to use from here on out. Go street tune and/or dyno tune the car now Did this with ICS's car, MADEX's car, ITR Shawn's car and many others.
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Apr 25, 2006 | 07:04 PM
95gainfla's Avatar
smokes weed...everyday.
as soon as i started my engine all hell was broke loose
I <3 RooR!!!!!!
Old Apr 25, 2006 | 08:30 PM
civicized's Avatar
If you paid a pro builder I would do what your builder tells you. If you don't and something lets go, he might tell you "tough luck, you just blew the warranty and your motor."
Old Apr 25, 2006 | 08:54 PM
mtber's Avatar
+1
