Need Help w/Turbo Setup on my EF!!!!!!!!!!!
Old Apr 24, 2006 | 12:24 PM
TurboJdmEk's Avatar
is on blocks...
Exclamation Need Help w/Turbo Setup on my EF!!!!!!!!!!!
i have a ef 88 hatch with a gsr block and b16 head now i've heard since the combustion chamber on the b16 is larger it lowers my compression so i wanted to go turbo i got a garrett t3 turbo on here and a friend of mine is going to get me a turbo manifold now this is where the question is what else do i need to get my car turboed out!? i want to push like 10 lbs on the street and 20-25 lbs on the track im on a limited budget so i dont really want to go into internals and shit but if i dont would i be able to push those amounts of boost? if not what numbers should i look to push without getting new internals so really just looking for someone to tell me what i need to completely put the turbo on?? someone help please lmk people??
its coming...
Old Apr 24, 2006 | 01:59 PM
aj187's Avatar
FORE:exalt
You need larger injectors, oil lines, intercooler piping,intercooler, downpipe, bov, wastegate, fpr (if you dont already have one), and a good tuner. If i am missing anything that he needs to finish that turbo please lmk.
Old Apr 24, 2006 | 02:18 PM
95gainfla's Avatar
smokes weed...everyday.
if you get dsm injectors(such as 450's), you'll need a resistor box(unless ef's have them, im an ek person)
also, 25psi on a stock gsr block isnt going to happen. sorry bud.
I <3 RooR!!!!!!
Old Apr 24, 2006 | 02:34 PM
aj187's Avatar
FORE:exalt
I am pretty sure they dont. And as for the 25 psi with a limited budget sorry but as 95gainfl said thats not going to happen.
Old Apr 24, 2006 | 02:47 PM
aj187's Avatar
FORE:exalt
Also if you havent already upgrade your fuel pump(Walbro 255lph), your ignition system(MSD), and spark plug wires(MSD or NGK). Also look into getting a turbo timer, boost controller, a nice street clutch, and other gauges like boost gauge, air/fuel gauge, oil pressure gauge, and fuel pressure gauge. Goodluck with it!
Old Apr 24, 2006 | 03:00 PM
DavidEK's Avatar
drives a truck
Old Apr 24, 2006 | 03:27 PM
Blown99civicSi's Avatar
EFI Tech/Tuner
No need for a MSD ignition system, the stock ignotion system is more than capable for supporting more HP than you are looking for and 25PSI is a bit much, on stock internals. which T3 turbo are you running anyway??
Modified Racing
Street Tuning & Dyno Tuning the greater east coast area for over 10 years and running!
AEM/HONDATA/MOTEC/FAST/DEFI & More
EFI-101 Certified
(941)628-4988
Old Apr 24, 2006 | 03:35 PM
DeadSexY's Avatar
diballacully slow
450 I have a nicely balanced set for 50 bucks
Old Apr 24, 2006 | 03:54 PM
aj187's Avatar
FORE:exalt
Yea, sorry the MSD is more of a option .
Old Apr 24, 2006 | 04:07 PM
EFI Tech/Tuner
Its cew, just didnt want him to think it was required
Modified Racing
EFI-101 Certified
(941)628-4988
