NEED HELP FROM OBD2B y8 OWNERS!!
Old Apr 19, 2006 | 11:48 AM
95gainfla's Avatar
smokes weed...everyday.
Default NEED HELP FROM OBD2B y8 OWNERS!!
Can one of you go out and look at your dizzy harness?
i need to know the colors/locations of the wires coming FROM the dizzy to the engine bay harness...
asap. thanks
rep for whoever helps.
I <3 RooR!!!!!!
Old Apr 19, 2006 | 01:46 PM
aj187's Avatar
FORE:exalt
Black/Yellow-ignition wire, Yellow/Green -ignition input signal wire, Blue-rpm output wire, Orange-CYP P wire, White-CYP M wire, Orange/Blue-TDC P wire, White/Blue-TDC M wire, LT Blue- CKP P wire, LT Blue/Yellow-CKP M wire. If you need the pin-outs i can get those for you later on..?
Old Apr 19, 2006 | 01:53 PM
95gainfla's Avatar
well, i know what the COLORS are, i more kinda need something like....
white-yellow/black-blue-yellow/green
black-red-white/blue-darkblue
or whatever....thanks
I <3 RooR!!!!!!
Old Apr 19, 2006 | 02:14 PM
aj187's Avatar
FORE:exalt
Im just a little confussed sorry, do you need where they connect into the connector, or the pin-outs for them w.e..
Old Apr 19, 2006 | 02:16 PM
95gainfla's Avatar
i need the diagram for the harness plug ON THE DIZZY. it MUST be obd2b with 8 wires.
i was rewiring my obd1 dizzy to my obd2b plug, and i PULLED the wires out of the harness plug when i did it so i didnt have to solder and it'd be all oem and such, but i messed up, and now i have no idea what hole in the harness plug the original wires went.
I <3 RooR!!!!!!
Old Apr 19, 2006 | 02:44 PM
aj187's Avatar
FORE:exalt
pin 1-yellow/green, pin 2- blue/green, pin 3-orange/blue, pin 4-orange, pin 5-not used, pin 6-blue/yellow, pin 7-white/blue, pin 8- white.
Old Apr 19, 2006 | 03:10 PM
95gainfla's Avatar
that sounds like an obd2A dizzy, is it?
I <3 RooR!!!!!!
Old Apr 19, 2006 | 04:47 PM
Derka's Avatar
TR Balla Donor Supreme
Bring it to neal
1998 crv daily beater
Old Apr 19, 2006 | 05:11 PM
95gainfla's Avatar
ill call him tomorrow and see if he can hook me up. he came out to my house to help me when it wouldnt start before.
he sat in my car for 3 seconds, and said he knew what the problem was.......i had the wrong conversion harness..
I <3 RooR!!!!!!
Old Apr 19, 2006 | 05:34 PM
aj187's Avatar
FORE:exalt
It is obd2b.
