guys need help
Old Apr 17, 2006 | 03:35 PM
Vroooom's Avatar
Default guys need help
do i need to change the motor mounts on my 94 hatch cx if i am putting integra ls in it, and also its 97 itegra obd2 swap i am putting in my 94 hatch i know it needs a obd1 computer ,what else i have to change please help
thanks
Old Apr 17, 2006 | 07:20 PM
95gainfla's Avatar
smokes weed...everyday.
axles, im shaft, mounts, shiftlinkage, and ecu.
I <3 RooR!!!!!!
Old Apr 17, 2006 | 07:24 PM
integraman89's Avatar
lost u already???
you will also need a conversion harness on top of the swap mounts axles linkage and ecu, go to www.hasport.com they should have all you will need for that swap.
Old Apr 18, 2006 | 07:05 AM
FC_V8's Avatar
well for my swap i used.....gsr shift linkage,gsr rear mount and my si driver side mount. the only mounts u need is a ls driver side mount and the ls rear mount and the ls shift linkage. as for the wirring...i dont do that..sorry.
Old Apr 18, 2006 | 07:06 AM
FC_V8's Avatar
did u get the axels with the motor?? cause u'll need those too.
Old Apr 18, 2006 | 11:48 AM
Vroooom's Avatar
yeh i got everything all i need is a freaking delsol ac bracket from b16 they told me so i need that i guess i dont know
