Need a place to replace my trailing arm bushings
Old Apr 16, 2006 | 03:45 PM
sam21's Avatar
Default Need a place to replace my trailing arm bushings
My trailing arm bushings are pretty bad,not really a DIY job because it has to be pressed out,who can do it?some place where i come with the car and part and they'll install it for me right there...
thanks y'all
Old Apr 16, 2006 | 03:50 PM
KJ's Avatar
KJ
bored at work
If you replace with an energy suspension bushing then you can remove the old one with a propane torch and install the new one with a c-clamp or press. Done it several times. If you replace with an oem then you will definitely need a press or they make a special tool just for it that sells for about $300.
Old Apr 17, 2006 | 10:45 AM
DOHC16CRX's Avatar
CARPET GUY
I HAVE ALWAYS just hammered them out and cut the old rubber out the metal ring and used energy suspensions..They are not pressed in hard at all.
EATING FORDS-SHITTING CHEVY'S
MOBIL 1 LUBE
11210 Causeway Blvd. Brandon 33511
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
At the Mobil 1 Lube in brandon we service all your automotive needs.Specialize in Honda/Acura. B series swaps etc. No job to big or small.We are located right in front of Walmart. Ask for Nate.
Old Apr 17, 2006 | 06:10 PM
sam21's Avatar
bump for more responses
Old Apr 18, 2006 | 03:36 AM
KJ's Avatar
KJ
bored at work
Decide if you want to put a stock one in or go aftermarket with a polyurethane or maybe even a sphericle bearing joint ($$$). The stock one has a rubber center bonded to a sleeve that is pressed into the trailing arm. If you want to replace with oem you need a press and/or the special tool that I mentioned before. The aftermarket one leaves the oem sleeve in the trailing arm but requires you remove all the rubber to put the new urethane bushing in. You will also be reusing the stock "bar" that runs through the middle of the original rubber piece. The best way I've found to remove the rubber stock portion to put a urethane bushing in, is to burn out the stock rubber and then use a wire wheel to remove the left over ash before pressing the new urethane bushing in.
Good Luck.
Old Apr 18, 2006 | 08:15 AM
DOHC16CRX's Avatar
CARPET GUY
ya,burn it out works great and a roto zip also does the job..its not that hard..the hardest part is getting the energy suspension bushing into the metal sleeve.IF you want some that are already ready to install i might have a set ready to go..i will check and see..i know i have the bushings here some where..
MOBIL 1 LUBE
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
