suspension question .. lowering
Old Apr 16, 2006 | 12:52 PM
quickex99's Avatar
Scissor Me Timbers!
Default suspension question .. lowering
ok ... I am havin some troube with the rear of my car lowering more... the ground control coilovers are all the way down but it is still not low enuff... i have tokico blue struts .. I was wondering if maybe i got different struts it would change the height... or am i just screwed... thanks a million
Old Apr 16, 2006 | 01:45 PM
integraman89's Avatar
lost u already???
yep, tokico makes a 5 point adjustable strut, its white. u can put that on with the coilover and it should workout a whole lot better that way you can adjust both of them. you can talk to blown99civicsi or check out his site www.modifiedracing.net see if he carries them
Old Apr 16, 2006 | 04:46 PM
Outkasted24's Avatar
** I ♥ Old Skool **
Do you have Coilover Spring Top Hats installed along with the factory Top hat?
If you do have them on...Take them off.
You can also take the bottom pearch screw out and that will drop it a lil bit more.
An Aftermarket Shock should allow you to go lower then any OE Shock would, So I can't see your Tokicos holding you up.
Let us know what your whole setup consists of ................
My Flickr
slam.poke.drop.tuck.dope
Old Apr 16, 2006 | 06:57 PM
Blown99civicSi's Avatar
EFI Tech/Tuner
+1^^^^^ what are your running, model struts and with or without top hats,
Modified Racing
Street Tuning & Dyno Tuning the greater east coast area for over 10 years and running!
AEM/HONDATA/MOTEC/FAST/DEFI & More
EFI-101 Certified
(941)628-4988
Old Apr 16, 2006 | 06:59 PM
EFI Tech/Tuner
BTW 1st, how low are you wanting?? 3"'s is alot and very few GOOD quaility coilovers adjust lower than that, besides you are losing performance going that low(handling), Why?? for show?? if so get bags
Modified Racing
EFI-101 Certified
(941)628-4988
Old Apr 17, 2006 | 06:54 AM
quickex99's Avatar
Scissor Me Timbers!
those are good questions suspension was already on the car when purchased... but the rear coilovers are all the way down a nd its still not that low
Old Apr 17, 2006 | 11:58 AM
** I ♥ Old Skool **
Also something to look for.........Every shock has a washer that sits halfway down the shaft, This is so the dust cover doesn't compress all the way down.
Most people that install coilovers on their car simply forget to remove that washer.
This washer will bind up the Coilover top hat and keep the car from lowering all the way down....I've seen it a hundred times .
Just Something else to look for.................
If you get time, Raise the back of your car up...Take a pic or two of your setup....And I can walk you through what needs to be removed/replaced
My Flickr
Old Apr 17, 2006 | 12:15 PM
quickex99's Avatar
Scissor Me Timbers!
cool mang... prolly this friday when i have time... i hope its simply a washer.. talk to you then brotha!
Old Apr 17, 2006 | 02:13 PM
** I ♥ Old Skool **
My Flickr
