Upper Rad Hose
Old Apr 13, 2006 | 04:23 AM
SleepingB18's Avatar
just mike.
Default Upper Rad Hose
I got a 97 civic dx with a gsr , Im going to get a upper rad hose and kinda wonderin which car do I buy it for? i know the outlet on the motor is bigger than the stock rad. outlet. Which one?
Old Apr 13, 2006 | 05:42 AM
99B16Si's Avatar
integra.....also keep in mind tho, if you have the factory radiator the water neck coming off the radiator is a bit smaller in diameter than a 99-00 si or integra
Old Apr 13, 2006 | 05:57 AM
just mike.
yeah, thats where I was gettig at....heh thanks!
Old Apr 13, 2006 | 09:06 AM
When the hose is slightly bigger than the outlet, to take out the slack, some people wrap plastic electrical tape around the outlet, and a thin coat of red high temp gasket sealer to insure it doesn't leak.-Bob
