wiring help under dash
Old Apr 5, 2006 | 05:27 PM
japanbran's Avatar
Bo0st FTMFW
Default wiring help under dash
i have a 2001 integra gsr. i was driving the other day and my pass. bumper light fell out and broke the connector for the bulb. my fuse popped. i put a new fuse in, put the bulb in and tried it. they wouldnt work, and it blew my tail lights. i told my friend to change my fuse while i rewaired the bulb.. and he put in a fuse that was too big and when we tried it the fuse burt the wires in the underdash fuse box friends dont let friends helpwith cars.. so, how can i rewire the underdash fuse box so they work again.. i was thinking using one of the blank fuses underthere.. would that work? how hard is it to do that? if anyone wants to stop by and help me.. if you know what your doing. pm me. i will pay. i need these fixed asap
phearable.net
R.I.P DJSTANG. YOU WILL NOT BE FORGOTTEN!!!!
Old Apr 6, 2006 | 08:22 AM
japanbran's Avatar
Bo0st FTMFW
phearable.net
Old Apr 6, 2006 | 06:59 PM
japanbran's Avatar
Bo0st FTMFW
phearable.net
Old Apr 7, 2006 | 08:06 PM
TSX24L's Avatar
get a electrical schematic for your car, or simply try replacing the fuse box(underdash) with someone elses. (rewire the underdash fuse box??) why would you need to do that ?
Go through that schematic though, check the taillight relay etc.. you will have to look at the diagram. usually fuses are 2 times more then what is installed from the factory. Sounds like though that you have fuses in the wrong places or whatever the hell your doing. or a bad relay now.
Old Apr 7, 2006 | 08:42 PM
japanbran's Avatar
Bo0st FTMFW
mt taillights work now, i replaced the fuse for it. do you know where the relay is for the turn signals?
phearable.net
Old Apr 7, 2006 | 09:22 PM
TSX24L's Avatar
iam guessing on the right side under the glove box area. Iam not sure with a integra.
Old Apr 8, 2006 | 08:39 PM
aj187's Avatar
FORE:exalt
The turn signal relay is on the interior fuse block, at the top and all the way to the right. Should be right about a 20, 15, and 10 fuse.
