B20b into CRX?
Old Apr 5, 2006 | 03:29 PM
NeEd4SpEeD08's Avatar
PIT CREW!!!
Arrow B20b into CRX?
I got a 90 crx and i'm plannin on putting a cr-v motor in it (B20b) I was wondering if anybody knows if I will have to mess with motor mounts or cut out anything or just anything that i will have to mess with, that ya'll know about?........Or would an LS be easier? Thanks
Lindsey & Brian
Old Apr 5, 2006 | 03:34 PM
freakasis's Avatar
the ls and crv motors are both b-series motors so you will need to use the same mounts for either one....and the best tranny to use is a 90-93 integra tranny or a jdm b16 cable trany. and you will need custom mounts and a large hammer to dent the frame....good luck.
Old Apr 5, 2006 | 03:37 PM
PIT CREW!!!
thanks for the help bro any other comments???
Lindsey & Brian
Old Apr 5, 2006 | 04:30 PM
freakasis's Avatar
yeah....b20 + b16 tranny = wheel spin....have fun.
Old Apr 6, 2006 | 11:49 AM
juiced2ndgenteg's Avatar
you will also have to swap the b20 intake manifold for an LS manifold, other than that it is the same as the LS.
Old Apr 6, 2006 | 06:20 PM
Zxc4's Avatar
quit being scared, supercharged v8 Video - supercharged V8 honda crx 2 of 2
Old Apr 6, 2006 | 09:35 PM
LS4drCivic's Avatar
Is back in action!
B series swap mounts, B series shift linkage(either aftermarket or cut stock 90-93 linkage, swap out the intake manifold, use any B series cable tranny, hammer in the drivers frame rail for alternator clearence, if u plan on running a after market heder be sure ot either cut or hammer yoru front crossmember for clearnence, and also sometime to make things go smoother i hammer down the rear crossmember right in front of the rear motor mounts. and also is the car a Si/hf, or DX, if its dx yor also looking at doing a MPFI conversion
Is finally 4dr pimpin again
Rollings not racing either go from a dig or go home
Old Apr 7, 2006 | 01:00 PM
PIT CREW!!!
yea it is a dx what is a MPFI conversion???
Lindsey & Brian
Old Apr 7, 2006 | 04:44 PM
Zxc4's Avatar
multiport fuel injection
