vtec issues...
Old Apr 4, 2006 | 02:26 PM
EXtreme7200's Avatar
loves beer!!!!
Default vtec issues...
ok here goes....gotta ls/vtec with b16 head....p30 del sol vtec ecu...vtec will not engage....its throwin codes 21 vtec solenoid....23 knock sensor...and 43 primary oxygen sensor-heater....does the knock sensor code have anything to do with vtec not engaging?...and how would i fix the code 21? i was told to clean out the screen on the solenoid itself so im gunna try that....if that doesnt work what else might take away that code?
Old Apr 4, 2006 | 03:29 PM
javier vargas's Avatar
\o/argas
if your throwing a knock sensor code vtec will not work
Old Apr 4, 2006 | 04:33 PM
loves beer!!!!
wow so i should just get another knock sensor then i guess right
Old Apr 4, 2006 | 06:13 PM
mtber's Avatar
Code 21 is probably being thrown becuase your vtec signal wire is probably not wired correctly.
