need speedo and tach help
Old Mar 29, 2006 | 02:14 PM
quickex99's Avatar
Scissor Me Timbers!
Default need speedo and tach help
ok ... i was drivin my car the other day 99 civic dx and the speedo and the tach just stopped working all together!!... wheredo i start to fix this problem?? has anybody else had this happen? thanks in advance
Old Mar 29, 2006 | 02:20 PM
SmokinS13SR20's Avatar
That ginger...
Check fuses and grounds. Speedo cable may have popped out of the transmission.
Old Mar 29, 2006 | 03:02 PM
integraman89's Avatar
lost u already???
if the speed cable falls out that will also cause the tach not to work as well (in most cases), being as the tach is calculated within the speedo cable. in most cases if you have no speed cable hooked up, the car will never know what mph its taching at
