b20 vtec + turbo question
Old Mar 28, 2006 | 07:13 AM
uyht's Avatar
Default b20 vtec + turbo question
I am getting ready to install my new engine and I am wondering a few things.
1. My nitrous lines are these small rubber hoses: are these ok or is it better with steel cables, and if i need steel cables how do I determine the size of the cable to use?
2. My turbo is oilcooled so i need to run oil into it from the engine but i am not sure where to hook the line up to on the block, because its a b20 vtec as I understand it there is one oil pusher thing on the back of the block but that needs to run up to the head? Is that correct?
Thanks.
Old Mar 28, 2006 | 10:09 AM
DD.'s Avatar
DD.
Administrator
for nitrous lines you should look at these...at ZEX.com
3AN stainless steel braided lines, two feet long
and
4AN stainless steel braided lines, fifteen feet long
ZEX carries these...just look on the site...good luck
Old Mar 28, 2006 | 10:18 AM
Jay's Avatar
Jay
Janky
you remove your oil pressure sending unit and put in its place a T you then hook the line on one end of the T to your turbo and put your oil pressure sensor back in the other end of the T or a second line to your head. but honestly if your going to do this type of setup i would suggest buying one of the golden eagle ls vtec kits.
-J
Aim: o JankyJ o
http://jankycrew.com
