Help...Oil leak
Old Mar 28, 2006 | 04:31 AM
icegsr's Avatar
Default Help...Oil leak
I have an oil leak where it's common on the B series motors, under the vtech solenoid down to the block. I've changed the cam seal and the vtech solenoid seal with the filter. But it's steal leaking. What else could be causing this? It's not the valve cover casket, I can't see where it's leaking from.
Old Mar 28, 2006 | 07:26 AM
KJ's Avatar
KJ
bored at work
distributor o-ring
Old Mar 28, 2006 | 07:58 AM
SmokinS13SR20's Avatar
That ginger...
You can't see where it is leaking from but you know its not the valve cover gasket.....
Old Mar 28, 2006 | 08:03 AM
chi town brat's Avatar
! Ne shab'rud'ni !
have you changed the vtec solenoid seal that bolts up to the block only because it could be the seal on the top as well.
i changed both in my coupe, d16z6, and no more oil leaks.
Old Mar 28, 2006 | 11:27 AM
icegsr's Avatar
I didn't change the top seal on the solenoid. I only changed the one with the filter which is on the side of the solenoid. It can't be the top one because I can see it all around and there's no leaks. I'm going to do a real good cleaning this afternoon and see if I can see where it's leaking from.
Thx Smokin for correcting my wording .
Old Mar 28, 2006 | 11:28 AM
sxecrow's Avatar
EG2 CRX
Also, dont forget your gasket sealant/Hondabond.
Old Mar 28, 2006 | 12:44 PM
freakasis's Avatar
spray the whole engine with purple degreeser and then pressure wash it off....it will be really clean..than start it and watch.
Old Mar 28, 2006 | 01:05 PM
95gainfla's Avatar
smokes weed...everyday.
Originally Posted by KJ
distributor o-ring
+infinite.
I <3 RooR!!!!!!
Old Mar 28, 2006 | 04:05 PM
That ginger...
So your meaning you cant see where it is coming from so it may be the valve cover gasket?
