Getting poor gas milage / performance.
Old Mar 26, 2006 | 09:55 PM
djgizmo's Avatar
Sound Engineer for Hire
Default Getting poor gas milage / performance.
Well, after a week after I replaced my spark plugs / wires (last month is) I got great gas milage (442 to a 10 gal tank in my EK) Ever since then, my performance gas milage has gone down hill. I get a oil change regularly, change my air filter... so I figured I might as well check my plugs. Well, I check them and all of them look simular to the below picture. It has some kind of 'soot' on it and I've never seen that on a plug before. Is that common / normal?
Also, what are some other things that I myself can check to see what may be causing the performance problem.
I'm out in brandon now, and would like to replace the plugs with some NGKs, any suggestions on where to go?
Thanks!
"Your Music, Your Tunes"
Old Mar 27, 2006 | 04:05 AM
Old Renegade's Avatar
Cool Runnings
your reason for poor gas mileage is these ridiculous gas prices! nuff said!
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old Mar 27, 2006 | 06:31 AM
aj187's Avatar
FORE:exalt
+1
Old Mar 27, 2006 | 06:52 AM
oldandbusted's Avatar
autozone or discount has ngks
Old Mar 27, 2006 | 08:15 AM
djgizmo's Avatar
Any idea what would cause this 'soot' to build up in less than 2 months on a plug?
Old Mar 27, 2006 | 08:51 AM
running rich will black the hell out of a plug
Old Mar 27, 2006 | 09:54 AM
I concurr.-Bob
Old Mar 27, 2006 | 10:46 AM
djgizmo's Avatar
Thats what I suspected too... figured that might be causing the excessive fuel usage. Only went 170 miles and I'm down to a half a tank. Might get another 100-125 if I take it ez.
Problem is, I didn't do anything to make it run more 'rich' Anything I can do to check or most likely cause?
Thanks!
Old Mar 27, 2006 | 11:05 AM
djgizmo's Avatar
Could it possibly be an O2 sensor?
Old Mar 27, 2006 | 05:27 PM
integraman89's Avatar
lost u already???
is your check engine light on? or you may need to get a hotter firing spark plug, show the plugs to someone at the auto parts store and as them if you should get hotter plugs or not, and also are you gapping them to the correct gap size
