B out K in
Originally Posted by InsaneCivicSedan
Look at the second picture... You can see the vacuum nipple for the brake booster on the runner behind the throttle body...
this is correct. there is a vacume bar that connect all the runners together and comes out on each end of the ITBs. i tried a few different setup to to get the best possible map signal but nothing worked. alot of people hook the map sensor to one nipple and the other to the brake booster.i looped both vacume nipples together and used a vacume log. as for the hood i reinstalled my old hood to cut up as i have a CF one. here is a pic of the manifold i have on order and should have late this month or begining of April -
I did forget to give Props to Neil Sutton for the harness. it was plug and play and well done.
steve
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
K series on crack
S D M
man that looks clean..nice work..
EATING FORDS-SHITTING CHEVY'S
MOBIL 1 LUBE
11210 Causeway Blvd. Brandon 33511
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
At the Mobil 1 Lube in brandon we service all your automotive needs.Specialize in Honda/Acura. B series swaps etc. No job to big or small.We are located right in front of Walmart. Ask for Nate.
MOBIL 1 LUBE
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
Looks great Steve
http://www.myspace.com/jdmmike02
2000 Ford Expedition Eddie Bauer
2004 Kawasaki ZX6R - SOLD
any numbers so far? looks good.
Didnt dyno on the ITBs as i wasnt keeping them and didnt want to spend the money. When the IPS manifold shows ill fully tune and post #'s.
steve
steve
K series on crack
S D M
K series on crack
S D M
steve
steve
steve
steve
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Very nice setup! This has gotta be one of if not the fastest all motor street car in our area.
I love the way it looks on the outside...ZZZZZZZ
Arent the K series a bit smaller and lighter than B series also?
Props for keeping it n/a and resisting the urge to boost!
Now residing in Atlanta.....
