k20 question
Old Mar 25, 2006 | 03:33 PM
DOHC16CRX's Avatar
CARPET GUY
Default k20 question
ok i have a question..all i hear about now days is k series.I have rode in a newer 04 si hatch with a k20 type r w/ lsd,6 spd etc.It impressed the hell out of me..No power lose and pulled like a bitch to 9k rpms.Now my question,Is it realy worth the money and time/wiring that it takes to get these into rexes. I only ask cause there is a white crx running around clearwater with no hood that fucking sounds mean as hell and has the k series in it. I am praying i see him while i am out just so i can see the differance between a built ls/vtec and a k series.I hear that its a bitch and a ton of cash to get these wired up in rexes right.Anyone have any link's etc. of k series into crx info ?
EATING FORDS-SHITTING CHEVY'S
MOBIL 1 LUBE
11210 Causeway Blvd. Brandon 33511
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
At the Mobil 1 Lube in brandon we service all your automotive needs.Specialize in Honda/Acura. B series swaps etc. No job to big or small.We are located right in front of Walmart. Ask for Nate.
Old Mar 25, 2006 | 05:15 PM
na200whp's Avatar
Powered by BOOST
wiring is not bad at all if you have Neal Sutton do your harness for you. He does it for a great price and is basicly plug and play or you can drop off your car to him and he will do it all. I can vouch for his K harness as im running one.
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
Old Mar 25, 2006 | 05:23 PM
DOHC16CRX's Avatar
CARPET GUY
what are they doing for the ecu in them..anyone ever figure out what speedo and tac will work.i know there was alot of little issues when they first came around..does your hood close?
MOBIL 1 LUBE
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
Old Mar 25, 2006 | 06:43 PM
blackwagon's Avatar
"color blind kid"
Funny how I go out to find fun runs and never find a single race. I might be heading to sunshine with it this Wednesday if I can get my hood done by then.
To have the speedo work for a cable driven vss you can use a single cam vss, you just have to redrill the mounting hole on the little peice of metal that holds it down. I'm running a rywire harness, it's a jumper type harness and no wiring is needed if your going to run kpro/aem. If you want to run the immobalizer you have to wire in 4 wires. With all the plugs supplied he charged me 300 shipped. If you use hassport mounts the Crx hood does not close, a cowled skeleton-less cf hood will fit, as will the jdm hoods.
Again I sugest going to a k series specific board to read up if your serious about doing it yourself. If not pay someone, theres plenty of shops making a killing on the easiest swap i've done to date.
Learn how to use the feedback system! When people don't fallow through with a deal, fucking make it known! of course everyone has all positive points, no one fucking gives negatives for flakers, if you start giving negative feedbacks for flaking maybe people on tr will stop making stupid ass posts about wanting to buy shit then not showing up for the shit.
Old Mar 26, 2006 | 05:20 AM
DOHC16CRX's Avatar
CARPET GUY
man bro !! thats you in that rex..that bitch sounds sick..i seen you come down 126 ave the other day spinning thew 3rd all over the dam street.What k series is in that..that just a base k20?I realy want to run that thing..just to see if i can get it..If i ever go k series i will pay the extra for the type r.well anyways..bro that rex sounds like it fucking gets down..u realy need to run me one day...
MOBIL 1 LUBE
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
Old Mar 26, 2006 | 05:34 AM
DOHC16CRX's Avatar
CARPET GUY
is the k pro set up still around a grand?do you need to convert to obd1 or something to get the ecu to work?i am just trying to get an idea of what has came out now days.I knew it would be no time before they got it easy to bolt them in and wire them with out selling your right arm..I am sitting on a built ls/vtec as well as a new 0 miles ITR.When i finally run a k series then i will figure out if i realy want to go that route.I have thousands of dollars b-series.it would suck to start over..
MOBIL 1 LUBE
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
Old Mar 26, 2006 | 06:01 AM
BigBodySmith's Avatar
Retired Street Racer
If you have a built ls/vtec, go ahead and run that then. Why would you not want a hood on your car?? or a big ass cowl induction hood, its not a chevy. Make the car look stock, thats what I like. I would do a k20 rex if it were going to be a drag car, but if you put an ls/vtec making over 200whp in a crx, that thing will run 12s all day long. Your going to have traction problems in with both motors. I would just keep your mind focused on that ls/vtec. Play with that for awhile, and then, if you want more, then go that route. Dont waste all the time and money and start over. Remember the B motor is what made Honda known. Yea Ks are tight, 6 speed, 2L, cant go wrong. But in a Crx, strictly drag. Thats my 2 cents. Good luck with whatever you decide.
I dont know anything about the wiring.
My Old Honda
Old Mar 26, 2006 | 06:06 AM
Jaso0on's Avatar
Is now ballin!
+1, little bit of nitrous on that ls/vtec, some lensos with 22" slicks and a quaiffe and I don't see why it wouldn't go 11's..
RIP Kevin (Slo_Si) Gonzalez - 09/13/2006
Old Mar 26, 2006 | 06:23 AM
DOHC16CRX's Avatar
CARPET GUY
see thats what i thought..i have a zex 75 shoot on it to.BUT this is a drag car so i dont care what it looks like..look in my gallery.I have nothing in the car that does not need to be there.that goes for wireing as well..its just a shell..this car is just for fun and track days.i will not be on the street much.i will get some new pics up latter but i have some older pics in the gallery.
MOBIL 1 LUBE
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
Old Mar 26, 2006 | 06:29 AM
DOHC16CRX's Avatar
CARPET GUY
i know rex's have the worst traction problems so i have spared no cost on getting my suspension and tires done.went with koni yellows w/ nuespeed race springs and full camber adj. energy suspension complete hyperflux kit,brand new g-force drag radials and i have traction bars so i hope it does pretty good when it comes to traction.
MOBIL 1 LUBE
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
