? auto to maual swap
Old Apr 30, 2006 | 12:07 PM
  #31 (permalink)
frankenstineSOHC's Avatar
i did this swap in my 93 ex did not need to swap the ecu and i didnt swap the tranny mount it was just a little slanted it was fast as hell untill i flipped it 3 times total swap only cost me 200 bucs
Old May 5, 2006 | 05:33 AM
  #32 (permalink)
lilmike13's Avatar
SAVE THE SOHC!
i want it to be perfect tho
93 del sol si (project)
88 honda cvic ef (daily driver)
hit me up on fb ( www.facebook.com/stewartracing13 )
TR "Old Skool EF" Member #166
Old May 5, 2006 | 06:46 PM
  #33 (permalink)
integraman89's Avatar
lost u already???
im with him, a slanted engine doesnt look too hot. perfect is almost always the way to go, dont be cheap cuz cheap will turn out to be cheap (p.o.s)
Old May 7, 2006 | 02:52 PM
  #34 (permalink)
abadgsr's Avatar
To Do It Factory Correct Like I Did, I Drilled The Spot-welds Out From A Donor 5spd Del Sol Removed My Auto Bracket And Had The 5 Spd One Welded On, Be Sure It's Lined Up Correctly Too Crooked Engines Or Tilted Ones Look Less Than Professional Or Stock......good Luck.
