brake question
you mean replace your drum brakes to disk? If your talking about your 99 ls. It should come with rear disk.
If your talking about putting your front rotors on the rear because of size? No. Or just out of curiousity for some weird reason no.
the front rotor will hit the strut assmbley cuz it has to slide on futher to be able to put the lug nut on them, like i said before if you take one of each and lay the down flat with the ground, the rear rotors are about an inch or more shorter
With some cars, they need some fitting.
Example, for the front rotors to fit on the rear of my Accord, bolt pattern is the same.......I need to reduce the hub size by about 1/10 inch and make a bracket to hold the disc caliper, plus a parking brake solution.
The easiest way to tell about yours is to unbolt them and see if they fit by bolt-on, or need a little machining, or if they fit at all.........-Bob
Originally Posted by zuir18
Was wondering if you can put the front rotors on the rears?Just wondering.
