troubleshoot my tach problem please.
Old Mar 23, 2006 | 07:58 PM
djlobes's Avatar
Im sofa king we todd did.
Default troubleshoot my tach problem please.
i installed an autometer tach in my 93 dx hatch. I connected the green(signal) wire to the blue wire under the hood right next to the firewall on the drivers side. I read that in some how to thing. of coarse i connected power, ground, and light wires as well. The lights on the tach work fine and the needle on the tach moves when i rev on it but its not correct. ie. when i know im at well over 5k the tach only says like 3 or 2.5k. im thinking it could be from a bad ground but im not for sure that would result in my problem. any help?
Old Mar 23, 2006 | 09:51 PM
aj187's Avatar
FORE:exalt
Check the ground, maybe try re-grounding it somewhere else. Also does that blue wire lead to the coil? If so maybe try putting your signal wire closer to where it comes out of the coil to get a better output signal.
Old Mar 24, 2006 | 03:58 AM
Old Renegade's Avatar
Cool Runnings
if its a four cylinder you got to cut the blue wire on the back of the tach. if its a six i think you cut the brown and if its a eight you got to cut both. so out of the brown and blue wire on the back of the tach cut the blue one and that shuould solve your problem.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old Mar 24, 2006 | 06:27 AM
supra87's Avatar
i think if its a v8 you dont cut any, v6 cut brown, and 4 banger cut both. thats how mine was
Old Mar 24, 2006 | 02:57 PM
Cool Runnings
what guague you got? i got a phantom series 5" monster tach with shift light and i had the not reading correct problem at its first install but cut the blue one and its working fine ever since.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
Old Mar 24, 2006 | 04:13 PM
djlobes's Avatar
there are only 4 wires. red(power) black(ground) white(illum) and green(signal). so i dont know what your talking about cutting.
Old Mar 25, 2006 | 03:52 AM
Cool Runnings
look direcly on the back of the tach (the cup part) and you should see a blue and brown wire.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
Old Mar 25, 2006 | 07:25 AM
aj187's Avatar
FORE:exalt
I had this problem. Im assuming with the wires your naming that your tach is a small one, like one i had. The signal wire (green) connects to to the blue wire like you have, but you say next to the firewall? Well it should be the same blue wire coming out of the coil on the dizzy. You want to connect that green wire as close to the blue wire on the coil as you can to get an accurate reading. That was my problem when i installed mine.
Old Mar 25, 2006 | 10:20 AM
djlobes's Avatar
thanks, i think thats probibly the problem. i'll re wire it tommorow. thanks for everybodys help.
