cleaning products
wondering what's the best thing to use for oxydized head lights...mine are pretty chalky looking and wanted to clean them up....
Vincent Mancini : Don Lucchesi, you are a man of finance and politics. These things I don't understand.
Don Lucchesi : You understand guns?
Vincent Mancini: Yes.
Don Lucchesi: Finance is a gun. Politics is knowing when to pull the trigger.
your talking about the plastic part of the light right? just buy new headlights, it isnt worth the hassle to clean them up, or.... i have heard of a rumor that if you soak them in turpentine, or vinegar or something like that overnight the oxidization should be gone.... im not certain which to soak it in and or if it will work, but its worth a try. good luck
If the yellow is on the inside, You will need to take the housings apart (200 degrees in the oven for 6 minutes will soften the OE Glue up...And pry apart...) and do this process.
1- wetsand the lense with a 1500+ grit sandpaper or apply a Automotive body compound to the yellowed area.
2-Clean the oxydation that was sanded or compounded off with regular windex and a lint free towel.
3-Apply a liquid wax (like Meguires/Eagle One/turtle/3M/Etc.) to the area you are treating, let wax dry and then use a 3000+ rpm high speed buffer and buff the wax into the lense. (don't hold the buffer still on the area for more then 4 seconds unless you want the pad to burn into the plastic lense)
4-Repeat # 3- one more time...then put the lense back on the housing..put the housing back on the car...and enjoy Brand New looking headlights.
OR
5- PM me and I can do the whole process for you in less then an hour and a half for a small fee.
-Jeff
OR
-Jeff
if on the outside use DOT3 brake fluid! i swear it works
Married to EkCoupegirl
Current Cars
05 ZX6R FOR SALE! Help me pay for school
PM me for info.
95 Civic EX 4dr- D.D.
99 GMC Sierra 5.3l ext. cab. Under construction
05 Kawasaki Ninja ZX636R Plasma Blue
Current Cars
PM me for info.95 Civic EX 4dr- D.D.
swing by my work one day and i can fix it for you if its on the outside. 400 grit sandpaper then 1500 grit and then buff it out with a light compound. i do it all the time at work havent had a problem with them yet
They say when a shark attacks you're supposed to punch him in the face. Then what, poke him in the eye with your nub.
