breather?? catch can?? differance?
Old Mar 23, 2006 | 10:57 AM
TIM TIM TIM's Avatar
could be worse
Default breather?? catch can?? differance?
breather relieves pressure from crank case, and catch can releases it from teh head right?? if im wrong please explain.... basically i have blow by and want my car to be as SAFE as possible. also where do i get an endyne breather/catch can at for the best deal?? (i tried ebay, google, hondatech ect.. no luck)
aim:because tim said
Old Mar 23, 2006 | 11:15 AM
99B16Si's Avatar
a breather for example is the little filter looking thing youll see on valve covers and most moroso style catch cans. a catch can is a baffled container that separates oil and air. It "catches" the oil and allows the air to be released.
Call larry at endyn directly if you want a catch can setup, number is 817-924-9334
price is $164 shipped
Old Mar 23, 2006 | 03:26 PM
could be worse
ok so whats the point of the breather?I have the little filter on there... is that what i will be changing if i do the endyne thing? I thought that the endyne catch can was to help release the crank case pressure
Old Mar 23, 2006 | 04:09 PM
lzylst's Avatar
The catch can hoses are attached to the back of the block with the two supplied fittings in the endyn kit. The breather/little filter is attached to the valve cover. That is just one way to do it.
Old Mar 23, 2006 | 04:50 PM
99B16Si's Avatar
the filter just keeps oil from slashing out, it helps keep the liquidy part of the vapor in the catch can. it there was just an open hole you get oil spray everywhere over a long period of time.
a catch can is a name of a baffled can, not a system. the endyn setup incorporates this type of can into its catch can setup along with fittings for the back of the block(where crank case pressure vents thru), lines, fittings, and a filter for the catch can
keep in mind a filter doesnt always have to be sucking in like an air intake filter, there type of filters work in the opposite direction...from the inside out
Old Mar 23, 2006 | 04:57 PM
could be worse
yeah well my filter blows out small amounts of oil .. not really blows out, but you can see some oil on the bottom of it... thanks 99b16si that makes MUCH more sence now.. rep for you
Old Mar 23, 2006 | 05:04 PM
b16a2pwr's Avatar
ALLJDM
Arrow
my favorite site is Wikipedia, that's where I get all of my information. So I've been reading up on an oil catch can. And you mentioned baffles. Can you diagram what a Baffle looks like please. This is what I came up with for Baffle.
oh and here are some relevant links about this subject from other sights.
Honda-Tech 1
Honda-Tech 2
Turbod16
AIM: jasonbadler
813.508.PLAN (7526)
TR Notary Crew: #001
Old Mar 23, 2006 | 05:13 PM
lzylst's Avatar
The baffle is inside the can. Basically its a series of channels that separate the oil from the vapors. The oil drops because of gravity and the vapors rise, flowing out of the filter.
