I Need Help!!!asap
it only messes up timing if you turn the crank, just make sure to put your cams in the right places. as long as you put everything back the way it came... your timing should be fine, but if your timing gets off, it is easy to re-time
yo if you need help call me man
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
727-510-6301
