lug lock problems PLEASE HELP!!
Old Mar 16, 2006 | 04:05 PM
quickex99's Avatar
Scissor Me Timbers!
Default lug lock problems PLEASE HELP!!
ok... i recently bought a 99 civic coupe and i am having problems with the wheel locks.. I brought it to advantage tire today .. and wanted them to slap on my new wheels well I explained to them i didnt have the key to the locks they said they would order them.. well they ordered them and one was 2 big and the other was 2 small .. so they sent me to rent n roll i bought a key that i thought would work.. but it kept slipping so as i was searching thru the car i found out the key was hidden under the spare tire.. so i tried using it.. it worked for about 5 lugs then started slipping i guess it stripped out.. what im really lookin for is a place that can remove my lugs on here ... i need a place asap !! thanks in advance!
Old Mar 16, 2006 | 05:24 PM
Outkasted24's Avatar
** I ♥ Old Skool **
The key fits inside the lug, Or around the outside?
If the key goes over the lug,........wrap some aluminum foil around the lug and try to loosen all the locks with the key and a 4-way...Not an air gun!!! and that should do it.
If the key fits inside the lugs.......Well, Your pretty much outta luck and need to order one or more of the identical lock key.
Good Luck Homie
My Flickr
slam.poke.drop.tuck.dope
Old Mar 16, 2006 | 06:20 PM
quickex99's Avatar
Scissor Me Timbers!
Good Luck Homie
it goes around.. so i will try the foil.. rep for joo my man!!
Old Mar 16, 2006 | 06:59 PM
Pyroproblem's Avatar
Porsche Tech/Honda Tech
if you need help still, call my cell and ill see if i can get you into the shop...
Be forewarned though, without the correct key, the lugs can be damaged taking them off so its a good idea to have an extra set on hand...
Now residing in Atlanta.....
Old Mar 16, 2006 | 11:27 PM
integra's Avatar
90% grind 10% sleep
harry did you buy tylers car?
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Mar 17, 2006 | 02:29 AM
quickex99's Avatar
Scissor Me Timbers!
no way mang.. that thing had soooo many electrical problems .. i have stuck with dericing the coupe i have..lol... its almost done too i will swing by the shop and show you mang
Old Mar 17, 2006 | 02:30 AM
quickex99's Avatar
Scissor Me Timbers!
i am probably gonna be calling you today !!.. thanks man
Old Mar 17, 2006 | 11:35 AM
quickex99's Avatar
Scissor Me Timbers!
your a life saver!!!.. thanks again nick
Old Mar 17, 2006 | 03:39 PM
b16a2pwr's Avatar
ALLJDM
got any pics?
AIM: jasonbadler
813.508.PLAN (7526)
TR Notary Crew: #001
Old Mar 17, 2006 | 04:00 PM
quickex99's Avatar
Scissor Me Timbers!
Originally Posted by b16a2pwr
got any pics?
pics of what??
